Shattering in 3d
aviel nahoum
Shattering in 3d
on Sep 4, 2015 at 9:12:32 pm
Hey,
i am trying to use the shatter effect on an image to create a puzzle like animation. i applied the shatter on the image plane, and enabled 3D, but all the parts of the puzzle are animated on a 2d plane, i.e it's not "real" 3d where i can use a camera to fly through the parts.
am i missing something?
Thank you!
John Cuevas
Re: Shattering in 3d
on Sep 5, 2015 at 1:32:53 am
You either have to use the camera controls within the shatter effect itself or change the Camera System to comp camera. Your layer can not have 3D enabled though or you get the 2d plane problem.
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
aviel nahoum
on Sep 5, 2015 at 3:16:42 pm
thanks!
so no way to have 3d with an "external" camera?
John Cuevas
on Sep 5, 2015 at 6:28:37 pm
Yes, just change the camera system to "Comp camera". The layer itself just can't be a 3d layer.
ThinkCK
Walter Soyka
on Sep 7, 2015 at 11:30:22 pm
[John Cuevas] "Yes, just change the camera system to "Comp camera". The layer itself just can't be a 3d layer."
For clarity, when the camera system is set to "Comp camera" as John mentions, the Shatter effect itself looks at the comp camera and renders the 3D view the comp camera should see.
Pseudo-3D effects like this, even though they may be aware of the comp camera, should never be applied to 3D layers. They handle the camera reference internally, and you do not want Ae to transform the layer they're on in the 3D system, too.
Walter Soyka
