How to make this shockwave fx
Susan Lan
on Sep 4, 2015 at 2:57:23 pm
How convert a shockwave like this video time 0:7
(I purchased that shockwave's pack)
into the blue shockwave that appears at 0:30 until 0:32 in this video (I don't mean the white ligth, I mean the background blue shocwave effect that seems goes in frotn (like a wind)
sorry my bad english, and thanks
Susan Lan
Re: How to make this shockwave fx
on Sep 4, 2015 at 3:10:08 pm
In other words, I have this:
http://i.imgur.com/GwHHAUH.jpg
and I want to achieve this:
http://i.imgur.com/IUBu4yo.jpg
or something similar... to make impact, thanks guys
Jim Scott
on Sep 4, 2015 at 4:16:19 pm
To make that horizontal "wind" effect using a Shockwave layer simply make your layer 3D and rotate it on the X-axis (-88 degrees, for example), and add a camera that has been moved over it in Z space so that as the shockwave expands it extends under the camera's position. Play with retiming that layer, or key framing the zoom of the camera, to accelerate the blast. Use another Shockwave layer for the vertical blast. Colorize your Shockwave layers as desired.
Susan Lan
on Sep 6, 2015 at 3:47:43 pm
Thank you Jim, I will try it
Daniel Waldron
on Sep 4, 2015 at 5:44:11 pm
Also, change the blend mode on your top layer to Add.
Susan Lan
on Sep 6, 2015 at 3:47:20 pm
Thanks Daniel
