When creating a new position key-frame from multiple layers and precompostions at once, strange glitching occurs.
Richard Determann
on Sep 1, 2015 at 10:20:48 pm
Hello, thank you for looking at my thread.
I am new to After Effects so when a problem like this occurs it is the worst because i don't know where to look to fix it.
Here's is a link to a video showing the problem I am having.
https://drive.google.com/file/d/0B8sZPLI4lyO_T0hNME01QlVGaUk/view?usp=shari...
I am running:
Windows 10 home 64bit
i7-5930K
12 GB DDR4
2 X GTX480 (Graphics Cards)
Temp Storage for After effects on an SSD
Project files and assets located on HDD
Thank you, any suggestions would be greatly appreciated.
Walter Soyka
Re: When creating a new position key-frame from multiple layers and precompostions at once, strange glitching occurs.
on Sep 2, 2015 at 1:17:23 am
If you want to move everything together, you could create a null, then select everything but the null and use the parenting pickwhip to make them children of the null.
Then animate the null's position. Any transformation made to the null will affect all its children.
https://helpx.adobe.com/after-effects/using/layer-properties.html#parent_an...
Walter Soyka
Richard Determann
on Sep 3, 2015 at 4:51:08 pm
Thank you very much for your quick response!
That worked really well, a very obvious solution that I just couldn't see because of my inexperience.
