Saving image with CC Time Blend
David Kim
on Sep 1, 2015 at 7:34:34 am
Hi guys,
I am using the CC Time Blend function and am trying to save a picture of the final frame after playing through the entire composition. When I try to use "save frame as" it only saves the current image without the time blending effects. How can I keep the time blend effects while saving a single frame?
Appreciate your help.
Kalle Kannisto
Re: Saving image with CC Time Blend
on Sep 1, 2015 at 10:53:43 am
Some ideas:
You could try rendering just the last frame (rather than saving a frame as). Don't know if it works in this case.
You could render entire movie as a image sequence and then delete all but last frame.
You could save the RAM preview and extract last frame with Photoshop.
Or you could do a screen grab (print screen) of the result -- if resolution allows. Although you probably compromise some quality if you do that.
David Kim
on Sep 3, 2015 at 2:56:53 pm
What I did in the end was just render the entire video clip and then extract the last frame using the new video file.
Thanks for your suggestions.
