Intro question
Bobby Salmon
Intro question
on Aug 31, 2015 at 6:01:27 pm
Hello all,
I am semi new to after effects, have created a few videos but still have a lot to learn, that being said, I am extremely interested in learning how to do a video similar to the older mountain men intro seen here:
I believe it is most likely done with masks, etc. but if someone could point me in the right direction, I would be grateful.
Thanks for your help!
Bobby
Dave LaRonde
Re: Intro question
on Aug 31, 2015 at 6:13:07 pm
I see 3D layers, particle systems, track mattes and extruded text, and that's just for starters. I only looked at it once.
Dave LaRonde
Promotion Producer
Kalle Kannisto
Re: Intro question
on Sep 1, 2015 at 11:26:41 am
Lots going on there but the basic method revolves around using a track matte of footage of splattering paint to mask out other footage. Then repeat that about 250 times and compose them into sets of pre-composed 3D layers with camera moves and finally add high contrast color correction.
Bobby Salmon
Re: Intro question
on Sep 1, 2015 at 10:19:57 pm
Yes there is alot going on, I love how they made it look so fluid but still busy. so in essence, I could take a splattering paint footage and use that as a mask revealing another video footage right?
Michael Szalapski
Re: Intro question
on Sep 2, 2015 at 2:00:07 pm
That sounds right. If the paint clip you have doesn't already contain alpha, you should be able to pull a key pretty easily as long as the background and paint color are distinct from each other.
You would then use the paint layer as a track matte [link].
- The Great Szalam
