Creating custom mask using something like rotobrush?
matt chapman
on Aug 27, 2015 at 11:19:06 pm
Hey all-
I need to be able to make a mask that is exactly the inside of a shape that is a fairly odd shape, but it is a still image and very high resolution.
Is there any plugin or expression that can create a mask in a similar way to the magic wand in Photoshop, or the RotoBrush in an animated thing?
The roto brush itself won't work for me because I need it to actually be a mask.
Matt Chapman
Dave LaRonde
Re: Creating custom mask using something like rotobrush?
on Aug 27, 2015 at 11:22:14 pm
I'd try using Autotrace on the weird shape -- if it's well-defined, you'll get one mask. Then double-click on the mask to bring up the Free Transform tool, and scale it down just a tiny bit.
Dave LaRonde
Promotion Producer
matt chapman
on Aug 27, 2015 at 11:33:26 pm
Thanks that made a pretty nice mask. Is there any way to reduce the number of points it makes? Right now its a lot as it is a circular shape.
Dave LaRonde
on Aug 28, 2015 at 12:11:24 am
It's a CIRCLE? Just use AE's elliptal mask tool. Lots fewer mask vertices to deal with.
Dave LaRonde
Promotion Producer
