short cut easy easing
Harry Mao
on Aug 25, 2015 at 8:06:00 pm
I'm having trouble creating an easy ease keyframe on my animations. I created few key frames and when I try to press F9 it does't do anything, I had to manually right click and select key frame assistant and then easy ease. Is there any way to fix this problem? Im using a Mac and AE CC 15
Nathan Walters
Re: short cut easy easing
on Aug 25, 2015 at 8:24:39 pm
What kind of keyboard are you using? I had a similar issue years back. Since Macs often use the F1-12 buttons as other functions (adjust screen brightness, volume, etc), sometimes you need to hold down "fn" and then press f9 or whatever f# button you need.
Nathan Walters
Halo Union Productions
http://www.HaloUnion.com
Daniel Waldron
on Aug 25, 2015 at 9:28:03 pm
You need change your Mac keyboard preferences to use Standard Function keys. Otherwise, hold down Fn like Nathan said.
Dave LaRonde
on Aug 25, 2015 at 9:34:46 pm
OR....
Highlight the keyframe in question. Right-click on it to reveal the keyframe assistant popup. Navigate to the easy ease funtion you want.
Dave LaRonde
Promotion Producer
