Video distortion, warp.
Kasper Nyman
on Aug 16, 2015 at 2:27:00 pm
Hey everyone.
The past couple of years I've noticed a small trend with distortion video. Do any of you know how to make these?
Link: https://www.dropbox.com/s/42u5l5qp19wsd6f/1.png?dl=0
Link: https://www.dropbox.com/s/536lhu7ujhbyofz/2.png?dl=0
Thank you!
Nyman
Kalle Kannisto
Re: Video distortion, warp.
on Aug 16, 2015 at 4:17:50 pm
You need to create a 3D elevation map from the grayscale image and use the same image as texture. Then add some lighting. How to achieve that automatically within After Effects for footage, no idea. If I were to do this, I would use Photoshop 3D, create an action and batch apply it to an image sequence. Not a very fast method, but you can leave it running the batch overnight.
Kasper Nyman
on Aug 16, 2015 at 6:09:33 pm
So actually you will recommend using Cinema 4D for this?
Either way thank you so much, a good help for google search for information.
Nyman
Kalle Kannisto
on Aug 17, 2015 at 7:30:04 pm
On second thought, I would recommend Trapcode Mir, it can do what I describe (once you have your bad tv distortion footage created).
Setting the Fractal frequency of Mir to 0 (and x and y scale to 0) you can use any image or footage to offset the surface in 3D. And you can map the same image/footage as texture on that surface.
Walter Soyka
on Aug 16, 2015 at 7:27:47 pm
Check out Mettle FreeForm [link].
Walter Soyka
