Dynamic link issue
Anton Grds
Dynamic link issue
on Aug 16, 2015 at 9:59:50 am
hello, my dynamic link isn't working anymore :(
I updated my after effects from cc 14 to cc15. I can open my old after effects projects, but when premiere cc 14 tries to connect with them via dynamic link, it seems that it cannot find any data in the AE project files... also, when I want to create a new after effects comp in premiere, a window pops up: "Connection to Adobe After Effects Dynamic Link failed"... can anyone help me? Thanks a lot!
Dave LaRonde
Re: Dynamic link issue
on Aug 16, 2015 at 4:24:33 pm
Stick with CC2014. You need a score card to keep up with the bugs in CC 2015 AND its bug fix.
There should be a bug fix for the bug fix in the fall. If things follow true to form, I would not be surprised if a bug fix for the bug fix for the bug fix also ensues.
Thus, if application stability is a higher priority than sparkly new features that may not work -- or break current features that DO work -- you may wish to forget CC 2015 even exists for the time being.
Dave LaRonde
Promotion Producer
