Problems rendering in AE
Joziah Ellison
on Aug 13, 2015 at 6:59:08 pm
I ran into a problem when rendering my finished work....
I have a 3D world with a camera floating around flying past floating videos. Everything is looking satisfying to me when I RAM preview it, but when I start the render.
My floating videos get blurred!
The videos are on a -64 degree angle on the Y axis so one side is closer to the camera and that half is blurred.
In my camera settings I have DOF on but I have set key frames, changing as the camera moves, focusing on the videos and as I said everything looks fine in the RAM preview. Any ideas as to why this is happening?
Here are two images before and after render...
Walter Soyka
Re: Problems rendering in AE
on Aug 13, 2015 at 7:58:11 pm
Please show screenshots of your entire UI so we can see what's going on in your comp, not just its output.
Walter Soyka
Joziah Ellison
on Aug 14, 2015 at 3:37:08 pm
Ok, here's the pictures......and thanks for your help.
This is a full capture of as much as I can fit on one screen.
And here's my cameras setting etc.
All of my key frames....
Lastly my comps and projects files....
Michael Szalapski
on Aug 14, 2015 at 9:34:08 pm
You have draft 3d turned on so you're not seeing the depth of field, but it is being applied at render. Simply turn the depth of field settings off for your camera (or change the focus point so that your videos are in focus. (To check that, turn draft 3d off for your comp.)
- The Great Szalam
Joziah Ellison
on Aug 14, 2015 at 10:56:53 pm
OK I see the problem now and here's my next problem. As soon as I tried either turning off DOF or Draft 3D I would get this:
A Example 1
See how I get this glitch, as if it's turning on and back off I'm confused but still trying everything because I need to get this done....
Walter Soyka
on Aug 15, 2015 at 12:49:58 am
Try clearing your cache.
Ae CC/CC2014/CC2015:
Edit > Purge > All Memory & Disk Cache
Ae CS6:
Preferences > Media & Disk Cache > Empty Disk Cache
Walter Soyka
