After Effects Not Reaching Realtime
Mark Chatman
on Aug 13, 2015 at 11:59:56 am
So I've after effects cc 2015,and when I add my composition from cinema 4d ,even though it renders all the frames,and it takes only 30% of my ram,it doesn't reach realtime(30),it's always at 28,29 sometimes jumps to 30,with every single animation I do,it seems like it does 28 fps at the same spot.
And yeah,my pc does handle cc 2015 correctly :
GPU: Gtx 750ti
CPU : I7 4770k
Ram memory : 16gb
Dave LaRonde
Re: After Effects Not Reaching Realtime
on Aug 13, 2015 at 3:36:34 pm
Do you still have AE CC 2014? Is this something you can do in it? If so, I'd use it.
I can't get the newest version, but from everything I've read it's not Adobe's most sterling effort. It sounds like the application development team got rushed... and haste makes waste in the form of bugs.
Dave LaRonde
Promotion Producer
Mark Chatman
on Aug 14, 2015 at 10:00:57 am
Yeah I do've it I've boguht it and i still have the serial key from it,shoudld I consider to downgrade? Since i've veen experiencing countless bugs on this version.
Dave LaRonde
on Aug 14, 2015 at 5:29:31 pm
You can run both versions on your machine. No need to downgrade. Just download it from Adobe.
By renting AE CC 2015, you have access to AE CC 2014, 2012 and CS6.
Dave LaRonde
Promotion Producer
