Null objects and transparency
Joe Bodego
on Aug 13, 2015 at 8:25:38 am
Is it possible to control the transparency with a null object. I know you can scale, rotate etc but i have no luck with transparency. Is there a work around?
John Cuevas
Re: Null objects and transparency
on Aug 13, 2015 at 1:09:10 pm
Add a Slider Control effect to the Null object, then just pick whip the child objects opacity(alt-click opacity stopwatch to enable expression) to the slider.
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Dave LaRonde
on Aug 13, 2015 at 5:43:57 pm
You can also animate the null's opacity and pick-whip another layer's opacity to it.
Dave LaRonde
Promotion Producer
Joe Bodego
on Aug 13, 2015 at 6:23:49 pm
Thank you, your answer helped, now it worked
