How to make a 3D rectangle to wrap a layer around?
Matthew Ruiz
on Aug 12, 2015 at 9:27:34 am
I am very curious as to how people make 3D rectangles that they then wrap layer or materials if you will around them in After Effects
Example: http://videohive.net/item/minimal-website-presentation-2/11805673
Kalle Kannisto
Re: How to make a 3D rectangle to wrap a layer around?
on Aug 12, 2015 at 12:59:55 pm
Possibly like this.
9136_3drectangle.aep.zip
You'll need to load some 1920x1080 footage to replace the missing one.
I didn't spend much time on it, so the edges don't line up that good, but you get the idea.
Matthew Ruiz
on Aug 12, 2015 at 3:15:03 pm
Thank you for the file! I unfortunately am unable to open it get version error problem is there anyway we could sort this out?
My current version is CS6
Thank you in advance,
Matt
Kalle Kannisto
on Aug 13, 2015 at 7:50:25 am
I can't save back to CS6, so the next best thing is to explain it. Here's a grab of the precomp:
If you look at the top view, I added guides where I wanted the footage to wrap, then duplicated the layer 4 times. I added a mask to each layer to create the top, bottom, left and right edges, moved the anchor points to the edge of the front face and rotated the edge slices 90 degrees on the x or y axis. Finally parented the edge to the front face.
I precomped it for tidiness, but that is not a required step. Remember to turn on collapse transformations if you precomp and want to use the camera in the main comp.
Paul Esteves
on Aug 13, 2015 at 8:43:50 am
You could also use something like this: http://creativedojo.net/introducing-dojo-extruder-script/ or http://aescripts.com/3d-extruder/ I think? Basically just duplicates the layer and offsets it in z space a bunch of times till you get your desired thickness. Not sure if it'll give you the exact results you want, but it could work.
