Strange text issue - text randomly changes or disappears
Trevor Plaza
on Aug 11, 2015 at 11:08:57 pm
I have a comp that is doing some strange things and I can't figure out why. I'm sure it's something simple but I just can't seem to find the answer.
The text changes size, font, or just plain disappears for what appears to be a random amount of time.
The only effect applied to that layer is a set matte effect to reveal the layer. When downsampling the text is fine and renders fine but when turning the quality back up, it starts acting strange.
Here is a screencast of what is happening. screencast
Thank you so much for any advice.
System Specifications
Intel Core i7-5820K CPU @ 3.30GHz
Asus X99-DELUXE
32 GB DDR4 - Quad Channel
NVIDIA GeForce GTX 760
Windows Version Windows 10
Walter Soyka
Re: Strange text issue - text randomly changes or disappears
on Aug 12, 2015 at 12:08:31 am
Try clearing your disk cache:
Ae CC/CC2014:
Edit > Purge > All Memory & Disk Cache
Ae CS6:
Preferences > Media & Disk Cache > Empty Disk Cache
Also, if you are running Ae CS6, make sure you've installed all the CS6 updates. The persistent disk cache feature was new in CS6 and there were a good number of bug fixes in the CS6 point releases.
Walter Soyka
Trevor Plaza
on Aug 12, 2015 at 5:15:16 pm
Hey Walter, thanks for the response. I am using AE CC 2015. Your solution for purging the memory and cache worked! I've never used that before and wasn't aware of it. I had tried clearing the cache but that had no affect on the problems I was seeing. The purge worked though. Thanks!
