auto blend mode
norman mol
auto blend mode
on Aug 11, 2015 at 3:53:04 am
hi
is there something like auto blend mode from photoshop in ae ?
in photoshop i used to cut the shape using lasso , past , adjust it , auto blend layer , done
i try to find smoothing Similar in after effect
thx
Walter Soyka
Re: auto blend mode
on Aug 11, 2015 at 4:33:32 am
There is nothing quite like Auto Blend in Ae; I suspect that's quite a challenging problem to solve given moving video instead of still images.
If you have some specific imagery you're looking to composite, perhaps you could post a screenshot or two and we could try to help you with some suggestions on technique.
Walter Soyka
norman mol
Re: auto blend mode
on Aug 11, 2015 at 4:49:22 am
thx for reply
something like
norman mol
Re: auto blend mode
on Aug 11, 2015 at 4:06:05 pm
also , im new to after effect but i know how to track and see some tut .. but im searching for Similar technique
Walter Soyka
Re: auto blend mode
on Aug 12, 2015 at 2:49:58 pm
I'd suggest color correction to get the skin tones from both source images as close as possible. You can pull keys based on the skin tones or use qualifiers in color correction effects like Colorista or Color Finesse to get pretty fine-grained control over just the skin. Red Giant Mojo has a "skin squeeze" property which you can use to even out skin tones to make them easier to adjust.
Walter Soyka
