Text clipped on dynamically linked text to Premiere :-(
David Honan
on Aug 6, 2015 at 1:54:46 pm
Hi from always cloudy about to rain York Uk :-)
Working in both premiere and After effects Ive hit a problem with dynamically linking below illustrates my problem:
9117_clippedtext.jpg.zip
Basically as the above link "Should" illustrate I cant get my works space to match the same dimensions as abode premier. Bloody nightmare! Gone into settings just cant work this one out. As stands I have a tiny workspace area in After Effects, but I need it to match premieres work space area if this makes sense.
Any advice welcome :-)
Walter Soyka
Re: Text clipped on dynamically linked text to Premiere :-(
on Aug 6, 2015 at 2:57:38 pm
Change the size of the comp in Ae in its composition settings (Cmd+K Mac, Ctrl+K PC).
It looks like perhaps your Ae comp is 1280x720 but your Pr sequence is 1920x1080.
Walter Soyka
David Honan
on Aug 6, 2015 at 4:27:43 pm
Brill thank you your suggestion worked :-)
