Question: Changing a static composition (image) into its identical .ai file?
Chris Lander
on Aug 2, 2015 at 11:13:02 pm
When I imported my .ai file, I began using the accompanied Composition in my workflow rather than the layers of .ai work.
Since I have applied transformations and effects to the Compostion, how can I substitute the actual ai files into its place so that the same effects will apply?
The ai file and the composition file are THE SAME static IMAGE. I just don't want to have to lengthen the Composition's duration in the composition settings dialogue box every time I want to change its duration. Can I sub in the Ai artwork as the new source?
Paul Esteves
Re: Question: Changing a static composition (image) into its identical .ai file?
on Aug 3, 2015 at 6:26:04 am
This tut will sort you out:
Basically select both layers, hold "alt" and drag new layer over the old layer. NOT sure if it works with compositions though. May have to copy/paste effects if it doesn't.
