configuring Dynamic Link
Marc Nibor
on Aug 2, 2015 at 4:21:40 pm
Not sure if this is a Premiere or AE topic.... but I'll try here first.
AE parts render VERY slow in Premiere, using only one core (12 are available) when I render a Project.
I already did some searching but only found bits and pieces. The most important seems to be that dynamic link uses only one core - period. But this info was many years old - maybe something has changed since than.
rendering realtime Previews of the AE parts in Premiere was also very slow. But seemed to speed up considerably once AE was closed.
What I want to know is this:
Is there any way to speed up rendering and use more than 1 core. (The info I found was quite old and maybe some dramatic changes were implemented ; )
So if anyone knows a way how to speed up things please let me know.
A confirmation that Dynamic link STILL supports only single frame rendering would be helpful too. Once I know for sure I can stop searching.
Walter Soyka
Re: configuring Dynamic Link
on Aug 3, 2015 at 2:43:02 pm
It's not precisely one core, but it is just a single render process.
Don't forget with Premiere that you can now render and replace [link].
You can also render some formats from After Effects with a project link that lets you re-open the AEP that rendered the output with a right-click and Edit Original in Premiere.
Walter Soyka
