How to check if a property value is readonly using extendscript?
Eskeletor de Mendoza
on Aug 2, 2015 at 12:26:32 pm
I'm writing a script that collects all properties from a layer and write them into an XML file. When I retrieve the values from the XML,
some values are readOnly and the toolkit throws an error.
Is there any way to check it, like readonly attribute on File object?
ie: layer.property().(readonly||readOnly)
If not, someone can tell me wich aproach can I take to go in the right direction?
Walter Soyka
Re: How to check if a property value is readonly using extendscript?
on Aug 3, 2015 at 2:40:40 pm
Whether an attribute is read-only or read/write is documented [link].
That said, you could use try/catch [link] to attempt to change the value of a property and recover if it fails.
Walter Soyka
Miguel de Mendoza
on Aug 19, 2015 at 10:27:56 am
This is what I was looking for. It Works perfect for me. Thanks!
