Change opacity over time with a fade not flicker
Ian Ellerby
on Aug 2, 2015 at 10:34:18 am
Hi
i'm trying to change opacity of layer over time, going from 100% to 50% in a 1 second fade, hold for 10 seconds at 50% opacity, then return to 100% over 1 second, hold at 100% for 10 seconds, and repeat and repeat etc
I can see lots of expressions with a flicker type approach, can't find on posts an opacity expression with a fade.
Thanks if anyone can help.
Ian
John Cuevas
Re: Change opacity over time with a fade not flicker
on Aug 3, 2015 at 1:04:20 pm
You could do this with a LoopOut Expression. Create the 1 second fade to 50, 10 second hold, then fade back to 100 and a 10 second hold. Then add the following expression to opacity:
loopOut("cycle")
Here's an example project: 9107_loopout.aep.zip
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Ian Ellerby
on Aug 3, 2015 at 1:27:26 pm
Hi Johnny
That's brilliant, a great solution, thanks very much for helping, do appreciate it.
Ian
