Vector objects in 3D get blurry
Lil Nagel
on Jul 31, 2015 at 8:10:44 pm
Good evening,
I have already searched the web and this forum, but did not find any solution to the following problem:
Whenever I have a vector-layer (e.g. a simple text created in AE or a vector imported from Ai) and switch it to 3D, it becomes slightly (but noticeably) blurry on the edges. Whatever settings I use, this effect won't go away.
For demonstration you will find a test-picture I created with a simple setup: just two white text-layers on a black background. No animation/ motion blur/ masks etc. Both text-layers are inside the same composition. The lower text is with 3D turned on, the one above without 3D.
I used these settings: continuous rasterization (by default as both are text-layers)/ preview: final quality/ full resolution.
I also added a snapshot from my UI, maybe I've missed a detail...
BTW: I use CS6 on an iMac running OSX 10.10.4.
Any help would be highly appreciated! Thanks in advance,
Lil
Roland R. Kahlenberg
Re: Vector objects in 3D get blurry
on Aug 1, 2015 at 1:09:33 am
You may have your camera's Depth of Field switched on.
HTH
- Roland Kahlenberg
TypeGEMs - the Definitive Type Gizmo for AE
http://broadcastgems.com/typegems/
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
http://www.broadcastgems.com/mographintensity_shapestext/
Lil Nagel
on Aug 1, 2015 at 2:51:55 pm
Hi Roland, thanks for the reply!
As I don't have any camera in my composition, there naturally shouldn't be a Depth of Field, or am I mistaken? Though there is the "active camera" creating the preview. Does this automatically install a "silent" camera with settings such as the DoF? If yes, where would I find the settings?
