rotating 3D cube
Ron Brajkovich
rotating 3D cube
on Jul 31, 2015 at 7:34:53 pm
I created a 3D cube, but am frying out my brain trying to get the cube to rotate on one corner, so that all side are readable in a 360 spin.
Dave LaRonde
Re: rotating 3D cube
on Jul 31, 2015 at 10:38:49 pm
Put a 3D null in the precise center of the cube. Parent the faces of the cube to the 3D null, and rotate the null.
Dave LaRonde
Promotion Producer
Ron Brajkovich
on Aug 3, 2015 at 1:52:42 pm
Hell Dave, Thanks for your reply. I'm learning as I go and appreciate your help.
So now I have the Null layer,3d, but can't seem to accurately set my anchor point in the center.
How do I accurately find the center of the cube with the Null Layer anchor point?
David Fuchs
on Aug 3, 2015 at 2:55:59 pm
There may be a simpler way I'm not familiar with, but you just need to use a bit of math. If you had a 200 pixel square comp, and stuck the null in the dead center, it's got a position of 100,100,0. 100px-wide squares would need to be arranged around that origin point—the "front" face would be at 100,100,-50, for instance, the back at 100,100,-100, one of the side faces would be rotated 90 degrees on the Y axis and placed at 100,100,-50, etc. Snapping and an easy way of adjusting anchor points for rotation such as the RepositionAnchorPoint script make it trivial to quickly do this; then you parent it to that null.
Note that you will sometimes get some fringes and gaps/seams in your cube, even if mathematically it's perfect. Setting the cube faces' blending mode to "Alpha Add" usually helps with that.
