after effects line glitch
Angela Herr
on Jul 30, 2015 at 8:02:36 pm
After doing a green screen replacement on After Effects I ended up with two line glitches where a line of the top layer is cut out on one frame. This has happened a few times before and I am not sure what is causing it or how to avoid it.
Dave LaRonde
Re: after effects line glitch
on Jul 30, 2015 at 8:12:23 pm
First thing to try -- purge your caches.
Second thing to try: transcode the footage to a different codec. I like transcoding to QT movies in ProRes 422, Photo JPEG, PNG or Animation codecs.
Dave LaRonde
Promotion Producer
Angela Herr
on Jul 30, 2015 at 8:22:11 pm
My footage is already in Prores 422. Will purging the cache fix the problem? Or are you suggesting that that is the cause of the problem?
Dave LaRonde
on Jul 30, 2015 at 9:59:23 pm
Purging the caches MIGHT fix the problem... and it's easy to do. Can't hurt to try it!
Dave LaRonde
Promotion Producer
