ToggleTabPanelMaximize
Fredrik Johansson
on Jul 30, 2015 at 2:31:15 pm
Anyone else have a problem with the keyboard shortcut not working in CC 2015? I usually have it mapped to Q and I have changed it in the shortcuts prefs file. But it's not working.
I also changed the trim layer to what I'm used to and that is working without a problem!?
Walter Soyka
Re: ToggleTabPanelMaximize
on Jul 30, 2015 at 3:07:36 pm
Are you running 13.5.0 or 13.5.1?
Walter Soyka
Fredrik Johansson
on Jul 30, 2015 at 3:30:15 pm
Hi
Running 13.5.1
Fredrik Johansson
on Aug 1, 2015 at 11:25:42 am
Suddenly remembered that I hadn't removed the default function mapped to Q! And if there are two functions mapped to one key nothing happens. I know that, usually, but forgot about it the other day.
So if you do change a keyboard shortcut; remember to check so it's not in use, and if it is remove or change the other function.
