Problem Splitting a Layer and Then arranging the new split layer with different in-out points
Jared Boice
on Jul 27, 2015 at 11:25:03 pm
This never happened in the past. But now has happened twice in a row between having my computer shutdown. So it appears it's a bug in After Effects CS6? The problem is, when I split a layer and then try to arrange the new split layer so that it uses different in-out points within the clip, when I try to play it back, the new split layer reverts back to the original in-out points. I know After Effects isn't supposed to be used as a Non-Linear Editor but I would hope it would be able to perform this very basic function properly.
Any idea what the problem is and if there's a viable solution??
Thanks in advance
Dave LaRonde
Re: Problem Splitting a Layer and Then arranging the new split layer with different in-out points
on Jul 27, 2015 at 11:58:07 pm
It might be the AE version. If you're not running AE 11.0.4, you should update it.
All updated? Try purging the caches. If your're on a Mac, it wouldn't hurt to repair permissions, either.
Dave LaRonde
Promotion Producer
