Unwrapping a globe?
Luke Luxor
Unwrapping a globe?
on Jul 27, 2015 at 9:00:16 pm
Hello all!
I am trying to pull off an effect where I have a sphereized map of the world (using CC Sphere) unwrap to go back to a flat map of the world, but I can't seem to find any way to do it within my budget (3rd party tools like Boris FX are a little pricey), is there ANY way at all to pull it off just within AE, and if not I will take the next best solution.
Thanks in advance!
Kalle Kannisto
Re: Unwrapping a globe?
on Jul 28, 2015 at 3:11:28 pm
Use the Optics Compensation effect instead of CC Sphere.
Luke Luxor
on Jul 30, 2015 at 2:00:51 pm
Alright! Let me give that a shot!
Luke Luxor
on Aug 4, 2015 at 7:04:50 am
After playing with it and looking around for a while, this isn't quite the effect I'm looking for, I might be missing something though, is there a tutorial or something you can point me to?
Kalle Kannisto
on Aug 5, 2015 at 7:26:09 am
Hi Luke,
I don't know if there are any tutorials for the optics compensation method. It just came to mind trying to think of any built-in effects that could be used.
The next relatively good option for creating a spherical warp with built-in tools is mesh warp (plus a circular track matte to make it appear perfect).
A more complex option is to use an animated displacement map (at 16 bits), but it would take me hours to figure out exactly how that would be set up.
I also tried the method of enlarging the CC sphere radius while decreasing the map size -- it ends up looking essentially the same as optics compensation, but is more difficult to do. And it doesn't go all the way to a flat map.
In any case, I believe the key is to come up with of a good way to animate a plane wrapping into a sphere rather than the other way around. There are several ways to do this, not sure what is the best for you.
Luke Luxor
on Aug 9, 2015 at 10:01:58 am
I think that is actually a really good idea, I'll poke around to see if I can come up with any solutions!
