animating opacity with expression using source black & white lines
pradeep naidu
on Jul 26, 2015 at 4:12:01 pm
hi guys i wanted to make some video loops i'm successfully making it but it consumes lot of time
from past 1 month i have created only 5 loops idea consist of 50+ loops
here's what i'm doing
https://images.creativecow.net/299442/bulbon.png [main comp]
now since it's taking lot of time i would like to use this animated white lines made in ae itself like this
https://images.creativecow.net/299442/whiteline.png [source comp]
so my idea is using this layer as source to animate the opacity the main comp using expression
can you guys help me out with expressions i need
thank you in advance
Peter Diefenthaler
Re: animating opacity with expression using source black & white lines
on Jul 26, 2015 at 5:33:21 pm
Do the white lines in the source comp consist of individual layers with opacity property? If so, put this expression in the opacity property of one layer, copy expression only and paste to all other layers in the main comp. It will copy the opacity of the white shapes based on layer order.
comp("source comp").layer(index).transform.opacity
Peter Diefenthaler
http://www.ideafirecreative.com/
