Pixar UP balloons
Ben Lewis
Pixar UP balloons
on Jul 23, 2015 at 3:11:17 pm
Hello everyone,
Im trying to achieve a balloon rising effect like the one seen in Disney's Up. Its for a title sequence for a wedding and I want it to be a 2D effect as opposed to 3D balloons. I want the movement to be realistic as opposed to achieving a photo-real look. If anything I want the effect to have a flat textured look. Balloons to 'lift' the words Amy & Dominic into frame and float out of frame.
Any help would be greatly appreciated.
Ben
Dave LaRonde
Re: Pixar UP balloons
on Jul 23, 2015 at 5:22:52 pm
Yow. I can think of NO instances of video shot with toy helium balloons lifting objects to use as a reference for realistic motion. If you want realistic, you may have to shoot it yourself.
Dave LaRonde
Promotion Producer
Joseph W. Bourke
on Jul 23, 2015 at 5:40:05 pm
You might find some good reference materials here:
http://www.pond5.com/stock-video-footage-sound-effects-music-after-effects-...
Bear in mind that some of them are 3D and some are real footage - you'll have to sort through them to find what looks right to you.
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com
Ben Lewis
on Jul 23, 2015 at 5:43:00 pm
Thanks very much. I was wondering if there was an expression I may use so the string attached to the balloons has a naturalistic feel.
Chris Wright
on Jul 23, 2015 at 5:48:52 pm
there might be a more exact example on here but this is what I found.
http://www.motionscript.com/design-guide/elastic.html
https://forums.creativecow.net/thread/227/16780#16782
https://forums.creativecow.net/thread/227/14249#14266
John Cuevas
on Jul 24, 2015 at 3:04:51 pm
Here's a project I made quite some time ago that I used to simulate a postcard falling, that uses sin waves to moved things back and forth gently. You might find it useful for a making a balloon float upwards.
7380_fallingfinal.aep.zip
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Ben Lewis
on Jul 24, 2015 at 3:31:30 pm
Thanks ever so much John. Im sure this will come in handy.
Chris Wright
on Jul 23, 2015 at 5:44:31 pm
i read an article that said that even particular's wind stuff is not organic enough and you can use ae's sketch to move your mouse like a balloon while ae is recording. also, if you have example footage, you can do a simple x,y track of a balloon to keyframes.
Matthew Woods
on Jul 27, 2015 at 2:07:04 pm
To really get the look you want, I think you need a physics engine.
A lot of 3d animation software has physics built into it. You could use a 2d shader to give it a more 2d look.
If you want to do it in AE, and can afford to buy the script, Newton2 is great for such things.
I actually have done a good balloon with a string in it. The string was composed of many tiny rectangles.
http://aescripts.com/newton/
Check out 9 Slice Scale.
A way to scale graphics while preserving the border and corners.
An FxFactory Plugin for AE, Premiere, Motion and FCP.
http://monadnock.org/9slice/
Ben Lewis
on Jul 27, 2015 at 3:30:29 pm
Thanks Matt. I have limited knowledge of 3D apps; I use cinema 4D a bit but have to watch my time on this project. I will take a look at Newton.
Cheers
Ben
