Libraries Linking
Allen Bullman
Libraries Linking
on Jul 15, 2015 at 11:03:17 am
I have created elements in PS and IL for use in PP an AF, I created a new library to put them in. That part does fine, and I can see them across all applications. When I am at work on my PC creating a AF project dragging the elements from the library into the project everything works great. Here is where the issue starts then I come home to pick up where I left off and I can see the elements in the library panel but they are not linked in the project anymore. I get color bars showing the image is missing. Should it not be looking to the cloud for this images and not the local pc?
Todd Kopriva
Re: Libraries Linking
on Jul 17, 2015 at 8:50:13 pm
No, the project is still needing to know where the files are on disk. When you've added assets to the project from a library, you've just taken a typical import step, and there is no retained connection back to the cloud for this asset.
After Effects product manager and curmudgeon
After Effects team blog
