'Super-Tight Junk Matte', or....
Steve Brame
on Jul 13, 2015 at 11:10:46 pm
For troubled greens screens, I've always relied on Aharon's 'Super Tight Junk Mattes' tutorial here on the COW. However, I ran across this similar, but much faster technique. Can anyone think of why it wouldn't perform as well as Aharon's method?
Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia GeForce GTX 770 * Windows 7 Premium 64bit * System Drive - WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) - WD Velociraptor 10K drive 600GB * Media Drive - 2TB RAID0 (4 - WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC * QuickTime 7.7.5
"98% of all computer issues can be solved by simply pressing 'F1'."
Steve Brame
creative illusions Productions
Steve Brame
Re: 'Super-Tight Junk Matte', or....
on Jul 13, 2015 at 11:23:15 pm
Sorry, apparently YouTube links to start a video at a specific point aren't supported. Jump to the 9 minute mark.
Steve Brame
Kevin Camp
on Jul 14, 2015 at 8:30:14 pm
it's pretty much the same. they both use the same principle - create a matte closely surrounding the subject. aharon's uses auto-traced masks and this one uses color key (or several color keys).
I remember the foundry had a tutorial that used 2 instances of key light... but the first instance may have been for an inside mask rather than outside mask... (to long ago)
one advantage of aharon's is after the auto-trace, masks render very quickly as you work with the footage, though i'm not sure that you'd recover the initial auto-trace processing time over the remainder of the project.
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
Marvin Mack
on Aug 16, 2015 at 10:47:23 pm
hello,
for some reason my Auto trace masks are not following the subject. Iv tried various methods the get a torn edge effect on an outer stroke with a rough edge effect and Auto trace is the only method i found that comes close to working. for some reason it is not working the way its suppose to, it matches my subject for about 10 frame and then stops.
here is an example:
a href='https://images.creativecow.net/300387/screenshot2015-08-16at6.37.37pm.png'>
can any one help.
Roland R. Kahlenberg
on Jul 15, 2015 at 10:28:55 am
This method is faster and does the job.
- Roland
TypeGEMs - the Definitive Type Gizmo for AE
http://broadcastgems.com/typegems/
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
http://www.broadcastgems.com/mographintensity_shapestext/
Jon Doughtie
on Jul 15, 2015 at 3:00:43 pm
Certainly going to add this approach to my toolbox. It may work better than another approach, depending on what you shoot.
Steve Brame
on Aug 10, 2015 at 10:57:57 am
I guess my question is now irrelevant since in AE2015 they've eliminated 'Color Key".
Steve Brame
on Aug 10, 2015 at 12:27:25 pm
You may use two instances of Keylight with the first one used to generate a tight matte. You'll want to hold down the CTRL key when sampling the backing color to sample a wider range of pixels (5x5) instead of a single pixel. This gives the keyer more colors to work with.
HTH
- Roland Kahlenberg
mark thompson
on Aug 17, 2015 at 12:15:16 pm
I think "Color Key" is still there. They have moved it to the "Obsolete" folder in the later AE CC releases but it worked last time I tried to use it.
I suppose putting it in the obsolete folder is a sign of future intentions but think it s still there for now.
mark
