CC Time Blend FX not appearing in Adobe After Effects CC
Usman Pirzada
on Jul 13, 2015 at 6:02:30 pm
Hey guys, so I really need to use the Time Blend FX and recently updated to CC from CS6. But the Time Blend FX plugin is nowhere to be found. I can confirm that it is actually present in the plugins directory like its supposed to be - it just doesnt show up in CC? what gives/ :( I have tried changing color modes and refreshing the preference file so far....
Todd Kopriva
Re: CC Time Blend FX not appearing in Adobe After Effects CC
on Jul 13, 2015 at 7:23:12 pm
CycoreFX removed CC Time Blend and CC Time Blend FX from version 1.8.0, the version included in After Effects CC 2015 (13.5). See the notes at the end of this:
what’s new and changed in After Effects CC 2015 (13.5)
After Effects product manager and curmudgeon
After Effects team blog
Usman Pirzada
on Jul 13, 2015 at 10:47:26 pm
Thank you for answering but why :( If they did that, why isn't there any substitute plugin?
Kevin Camp
on Jul 14, 2015 at 7:50:28 pm
i wonder the same thing... they don't mention anything on their site, but you can email them: support@cycorefx.com
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
Corrie Parks
on Oct 14, 2015 at 2:24:05 am
Did you ever get an answer as to why this was deemed obsolete and if there is a substitute? I use this as well, for a very particular type of frame blending to replicate a staggered mix in under-the-camera animation. It saves a lot of work. I even had it highlighted in a tutorial in a book that is about to be published and now we have to go revise the manuscript.
I would definitely like to know if there is something equivalent.
Michael Szalapski
on Oct 14, 2015 at 2:19:47 pm
Until Cycore responds, the good news is that, with Creative Cloud, you can install every version of AE back to CS6, so, if you really want CC Time Blend, you can load an older version and use it.
- The Great Szalam
Caleb McLaughlin
on Nov 12, 2015 at 3:58:22 pm
Depending on your project, you might be able to use Echo instead. I'm using it for star trails in a pinch. Would rather have Time Blend, but this will work if you need a quick blend without opening another version of AE. You just have to get used to the Echo Operator terminology in place of the blend modes.
Caleb
Corrie Parks
on Nov 28, 2015 at 4:09:49 am
Yeah, I've played around with Echo and with some of the other time effects. It just isn't as versatile. I hope they bring it back!
Jens Enqvist
on Dec 2, 2015 at 2:57:24 pm
They are actually both included still but marked Obsolete which means they will not show up in the effect menu. If you open an old project with layers having the effects applied, they will however show up in the effects window.
