Hi, can anyone point me out on a tutorial to achieve something like this?
Angelo Lazaro
on Jul 12, 2015 at 7:06:06 pm
I'm fairly new to after effects and just have very vague idea on how to achieve this, what I have in mind is to make a freeze frame but have no idea how to resume the frame after I'm done doing some effects on that frame.. I don't even know if that is the correct method so a little help on where to begin or the concept on how they made it will really help...
Dave LaRonde
Re: Hi, can anyone point me out on a tutorial to achieve something like this?
on Jul 13, 2015 at 12:21:04 pm
In a case like this, Time Remapping is your friend.
Dave LaRonde
Promotion Producer
Paul Esteves
on Jul 13, 2015 at 1:07:30 pm
You can use time remapping, which is probably the easiest way. But you can also duplicate your layer, freeze one at the frame you want to edit. Then cut the second layer at exactly that point, and split it for the duration of layer one.
This may help:
