Smoothening the Motion-field & Optical-flow of Video
Hayden Martin
on Jul 10, 2015 at 6:52:39 am
I've shot footage of models against green-screen on a 2.5K camera at 25p knowing that I cannot shoot any faster to achieve slow motion - to give me a higher degree of flexibility when it comes to remapping their movement I coordinated the models to move as slowly as possible.
Playing back the motion at 100% looks relatively smooth, although giveaways are apparent in the motion - whilst slowly changing poses from A to B, the models struggled to do so with absolute fluidity as observed in real slow motion where the movement would typically be fast whilst shot on a higher frame-rate...
My question is this:
If I want to eliminate minor bumps in the fluidity of the motion from pose A to B, could I simply run an analyses of the footage's Motion-field / Optical-flow then create a smoothen effect that essentially averages out this data in iterations of 100 frames...?
It seems feasible, and theoretically easier if shot against green-screen as there would be no interfering FG / BG information...
I've asked a similar question before but was redirected to interpolation hardware - I am sure my aims could be achieved through good use of expressions though...
Many thanks,
Walter Soyka
Re: Smoothening the Motion-field & Optical-flow of Video
on Jul 10, 2015 at 3:59:43 pm
If you want to try processing the motion vectors, you'll need a tool that gives you access to them. Twixtor Pro allows you to import/export motion vectors. Maybe you could try the demo to see if you can get the effect you're looking for?
Walter Soyka
Chris Wright
on Jul 10, 2015 at 5:03:12 pm
AE's timewarp can set vectors numbers higher, it supports roto masks if you precomp, so the bg won't get interpolated.
Also, you can precomp a video, precompose it, right click timestretch 50%, then apply timewarp 50% to the precomp.
That will create,decimate and average movement long as both numbers match. The higher the number, the more interpolation at a cost of softness.
filter-extreme will reduce softening of the image, but at a huge cpu cost.
If you need perfect quality, terrenex came out with a mini-hardware box. Or as walter said, twixtor pro has spline support to manually guide the warping.
© 2018 All Rights Reserved
