Is Keyframing really the solution?
Josh Arms
on Jul 6, 2015 at 12:21:03 pm
Hi.
I'm keyframing some footage of a bat flying towards the screen. Unfortunately there's a branch in the way.
Other than keyframing the branch out frame by frame, does anybody recommend another technique?
I've tried using Colorama to ramp up the greys and browns, etc, but so far no luck.
(The background is simple to remove, it's just the branch)
Does anybody have any ideas? I'd appreciate it before I spend two days straight doing keyframing!
John Cuevas
Re: Is Keyframing really the solution?
on Jul 6, 2015 at 1:56:38 pm
I'd use the rotobrush. Here's an older tutorial showing the basics, there are newer ones out there that get into the more advance newer features.
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Darby Edelen
on Jul 6, 2015 at 9:27:52 pm
If the camera is locked down then the Difference Matte effect may help you. You'll probably still need to do some roto work but it might give you enough for some good edge details.
Darby Edelen
