Hi
I'm trying to off-set some text along a curved line. What I have is one curved line along which some text flows, off-set this either side of the curved line are additional lines and I'm using 'baseline shift' except that the spacing of the text alters, expands when it's around the larger curve, and contracts around tighter curve, see enclosed image. Try to get the spacing the same throughout. Any ideas?
The single curve line is the shape for the background shape as well as the text form.
Thanks if you can help
Ian
