Cable tail
Gigi Marzo
Cable tail
on Jul 1, 2015 at 9:50:15 am
Hi... Im back again. :(
I have new dubt/problem. Is it possible that I cannot create/animate a cable that perfectly follow an object?
I tried it by the stroke effect with a mask, I tried to import the illustrator file and use the puppet tools, and also I followed the tutorial "cg snake".
So I have a headache!
If you want to better understand, take a look at the project. 9008_cable.zip
Im apologize for my little english and for not being clear enough. I'm really mortified to be always looking for help.
Meanwhile, I begin to understand just be scant.
Thank u in advance.
John Cuevas
Re: Cable tail
on Jul 1, 2015 at 1:31:21 pm
Check out this tutorial, maybe it might help you out.
How To Make A Wiggling Cord From Particles
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Gigi Marzo
Re: Cable tail
on Jul 9, 2015 at 9:21:29 am
hey!
I have solved by using the puppet too and following a little bit this tutorial
I hope it can serve to someone else!
Thank u!!! :)
