Keying out white... Trickier than usual
Dylan Hargreaves
on Jun 24, 2015 at 6:10:35 pm
Hi folks,
Trying to key out the white background of some stock footage of a goldfish, so it's swimming on black. I've tried a few methods and none are working well enough - luma key, luma matting, extract, Colorama output phase, (as per a sky replacement.)
The problem is, the goldfish fins are very whispy and its underside is pretty bright, so it's either posterizing nastily or leaving a big white outline - even with a choker.
Am I onto a loser here? Is it time to find some alternative stock, or is there one last solution that I've missed?
Thanks in advance!
D
Walter Soyka
Re: Keying out white... Trickier than usual
on Jun 25, 2015 at 12:40:20 am
Without seeing the footage, it's tough to tell, but...
You know how you can use UnMult [link] to generate alpha from black? You can do it with white, too. You just need to make an UnMult Sandwich: Invert, UnMult, Invert.
Sometimes it's nice to top your UnMult sandwich with a little Levels (Alpha channel).
Walter Soyka
Dylan Hargreaves
on Jun 25, 2015 at 9:02:08 pm
Thanks Walter - good to know for next time!
Ended up going for quite a radical technique:
1. Went to pet store
2. Purchased goldfish & tank
3. Shot goldfish against black background
4. Voila
And now my kids have a fish!
Walter Soyka
on Jun 27, 2015 at 4:06:34 pm
[Dylan Hargreaves] "3. Shot goldfish against black background"
Well, that's cheating :)
Walter Soyka
