3d Layers Jittering with Depth of field
Chris Powers
on Jun 24, 2015 at 5:14:10 pm
Hello,
I'm building an animation in After Effects that entails multiple 3d layers all being at the same point in z space, but with different masks cut out of them so that different elements of each layer show through.
(imagine 3 3d layers all at the same place, one has a square mask, one a circle, one a triangle, since they are all at the same point of z space, the ones layered "on top" of the others in the layer stack show up first...)
This works fine when I move the camera around normally, however, as soon as I add depth of field, the layers start to jump around, ones further down in the stack popping forward and then back.
I can fix this by nudging the layers forward or backward in z space, however, this is not only tedious, but also ruins the exactness of the image.
any ideas on how to keep the layers from jittering?
PS - Here's a tutorial I made a while ago that shows the sort of layering that I'm dealing with:
Peter Diefenthaler
Re: 3d Layers Jittering with Depth of field
on Jun 25, 2015 at 2:55:47 am
This sounds like z-fighting. Try putting an adjustment layer between each of the layers that are occupying the same space. Then the layers will no longer intersect each other.
Peter Diefenthaler
http://www.ideafirecreative.com/
Chris Powers
on Jun 25, 2015 at 1:05:58 pm
Ah, that sounds like a great idea, I hadn't thought of using an adjustment layer as a buffer.....that will probably do the trick, thanks Peter!
- Chris
