Quicktime export changes frame rate
Chris Thomas
on Jun 19, 2015 at 5:22:59 pm
I've made an animation in After Effects (no video; all animation) in a comp that's 29.97fps. Even if I force the frame rate to 29.97 in the render queue, the final animation opens as 30fps in Quicktime.
And to confound me even further, if I export an Animation codec of the same video from Quicktime (again, forcing 29.97), it exports a QT with a frame rate of 26.60! Any idea what's going on?
Roland R. Kahlenberg
Re: Quicktime export changes frame rate
on Jun 20, 2015 at 5:14:46 am
Do not use QT Player as a production tool. Use a professional tool to ascertain the correct meta data for your movies.
HTH
- Roland
TypeGEMs - the Definitive Type Gizmo for AE
http://broadcastgems.com/typegems/
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
http://www.broadcastgems.com/mographintensity_shapestext/
Adam VideoEditor
on Jun 20, 2015 at 6:00:59 pm
Sometimes After Effects can be a little funny with quicktime. I would suggest updating quicktime player if you haven't, and if the problem persists try downgrading. Find an older version below are two links. If the problem is still there then try reinstalling after effects and if nothing works just export to a different format. An mp4 is more universal than an mov and it also works with quicktime.
https://support.apple.com/kb/DL260?locale=en_US
https://support.apple.com/kb/DL443?locale=en_US
If any of this was helpful please follow me on twitter @ADVideoEditor and subscribe to my Youtube channel AD.VideoEditor
https://www.youtube.com/channel/UCtJAZgXTU0C4ir0N1P7Oxyw.
