Cannot change anti-aliasing mode for comp?
Adam O'Hern
on Jun 19, 2015 at 3:49:33 pm
Hi all,
According to the docs, there should be an advanced Comp setting for AA filter, offering 'none', 'box', 'tent', and 'cubic' modes. I'm not seeing this setting anywhere in the Comp settings. Can anybody point me to the right place?
Adam
Michael Szalapski
Re: Cannot change anti-aliasing mode for comp?
on Jun 19, 2015 at 4:53:42 pm
Are you in a composition that's using the ray-traced renderer? That's just for ray-tracing things. (icky!)
- The Great Szalam
Adam O'Hern
on Jun 19, 2015 at 4:57:06 pm
Ah, I see. So I guess I can't control the AA filter that's used on images more generally? I'm doing a UI mockup with tiny icons, and the AE AA filter is making them blurrier than they need to be. I'd like to use the raw pixel data if possible.
Michael Szalapski
on Jun 19, 2015 at 5:07:01 pm
Make sure you're placing your items on full pixel integers. If it's a two-pixel-wide line, you're splitting it between three pixels unless you have it at an x.5 position. Does that make sense?
And/or choose draft mode for your layers (and output).
- The Great Szalam
Walter Soyka
on Jun 20, 2015 at 4:00:27 am
See this post on subpixel resampling for more:
https://forums.creativecow.net/readpost/2/1063290
Walter Soyka
