script: split selected layer at current time indicator
Hamid Rohi-Bilverdy
on Jun 13, 2015 at 10:38:32 pm
Hi
Please guide me towards a tutorial or a thread on how to split selected layer at current time indicator from script.
I can't seem to figure this out.
/HRB
Walter Soyka
Re: script: split selected layer at current time indicator
on Jun 13, 2015 at 11:35:20 pm
With the layer(s) to split selected:
app.executeCommand(app.findMenuCommandId("Split Layer"));
Alternately, you could duplicate the layer, then adjust the out point of the original and the in point of the duplicate, which is what the split layer command does itself anyway.
Walter Soyka
Hamid Rohi-Bilverdy
on Jun 14, 2015 at 8:17:29 am
Thank you so much Walter.
Exactly what I was looking for. Where do I find something about executeCommand and findMenuCommandId??
Can the word Split Layer be changed with another command word??
Hamid Rohi-Bilverdy
on Jun 14, 2015 at 8:22:47 am
I am trying to make it split as it is now at current time indicator, but I also want to create a function that splits the layer at time markers.
Walter Soyka
on Jun 15, 2015 at 2:16:05 pm
[Hamid Rohi-Bilverdy] "I am trying to make it split as it is now at current time indicator, but I also want to create a function that splits the layer at time markers."
You can either programmatically alter the current time, or as I suggested above, duplicate the layers you want to split and adjust their in/out points independently.
Walter Soyka
Walter Soyka
on Jun 15, 2015 at 2:15:01 pm
[Hamid Rohi-Bilverdy] "Where do I find something about executeCommand and findMenuCommandId??"
There are features of ExtendScript which work across scriptable Adobe apps that are not documented in the After Effects-specific documentation:
http://www.adobe.com/devnet/scripting.html
[Hamid Rohi-Bilverdy] "Can the word Split Layer be changed with another command word??"
Yes. The line I showed above looks for a command in the menu system, then executes it.
Walter Soyka
