Re-opening a Cinema 4-D Lite file
Lowell Boston
on Jun 13, 2015 at 2:44:45 pm
I've recently begun doing tutorials for Cinema 4-D Lite through After Effects. As I was about half way through the first chapter, needed a break, save everything and quit both programs to continue later. 2
days later I return and ran into some trouble re-opening the Cinema 4-D Lite file. I had to start a new layer through AE to open the program, and once it was opened, I could access the older file I was working on.
However, the real trouble began when I saved the new material I was doing in Cinema 4-D lite. The changes were not reflected in the After Effects side.
Has anyone run into this problem before, or have I stumbled somewhere?
Lowell
