Strange motion blur/transparency effect
Andrea Digiorgio
on Jun 12, 2015 at 10:53:38 am
Hello everyone, yesterday i rendered a comp which has different animated characters inside. When i saw the export i noticed that some characters present a strange transparency effect, instead of the motion blur effect i had set initially. You can see an example in the attached image.
I tried different solutions:
-turn off motion blur in the character comp
-turn it on for all the layers inside it
-turn on "continuosly rasterize" on character comp. But nothing changed.
Some infos:
-Characters are animated with Duik
-Character Comps are 2000x2800px Square Pixels 25fps
-Main Comp is 1920x1080 Square Pixels 25fps
Thanks to everyone
Dave LaRonde
Re: Strange motion blur/transparency effect
on Jun 12, 2015 at 5:48:46 pm
Try purging your caches. I think the "ghost" image comes from it, when you had the arm in a different position.
Dave LaRonde
Promotion Producer
Andrea Digiorgio
on Jun 15, 2015 at 8:48:57 am
I've already tried but it keep showing this bug. I cleaned it 4-5 times in 2 days but doesn't work.
