Ai to shape
Igor Marcossi
Ai to shape
on Jun 11, 2015 at 12:01:57 pm
So, I have this pine cone:
http://i.imgur.com/1J5Wtdo.png
And when I make it shape, it turn into this:
http://i.imgur.com/x0w7z2C.png
What I do?
I need it in shape to work with Newton plugin!
John Cuevas
Re: Ai to shape
on Jun 11, 2015 at 2:30:42 pm
I took your pine cone, dropped it into a comp, selected the layer and used Layer > Autotrace and that created a pretty good mask. If you need it in a shape layer, you would twirl open your mask, select the pine cone "mask path" and copy that. Go to Layer > New > Shape Layer to make your new shape layer. Then twirl open the shape layer "Add" a new "Path", twirl open path, click on the "Path" next to the stopwwatch and paste. Then just add a fill if you need to see it.
Here's a project with the auto trace and shape layer of your pine cone.png.
8916_pinecone.aep.zip
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Igor Marcossi
Re: Ai to shape
on Jun 11, 2015 at 6:31:06 pm
Woah, that was fast!
Thx man, that fixed my problem.
Thx a lot, again.
