Using an anchor point is a good idea unless you have to adjust it?
John Hill
on Jun 10, 2015 at 5:53:28 pm
I'm animating photos and understand that I should use the anchor point instead of the position tool. But I am scaling out of a photo while changing the anchor point. The move does not happen the way I want and I need to adjust the anchor point. However I understand that one can only adjust the speed of an anchor point. The only option is to attach a camera to the layer?
Or is there something else I can do? Maybe using position is not so bad after all?
Dave LaRonde
Re: Using an anchor point is a good idea unless you have to adjust it?
on Jun 10, 2015 at 6:08:03 pm
Bad understanding, I think. The anchor point property can be keyframed just like opacity, position, etc. It's not a bad way to work as you animate scale along with it. It really helps if you need to pay close attention to the edge of a still and the edge of the comp.
Dave LaRonde
Promotion Producer
John Hill
on Jun 10, 2015 at 8:44:16 pm
Thanks, Dave! You're right. After setting some anchor key frames and working with the speed graph I was able to do it! Appreciate your guidance.
