Spot light doesn't track a null object
Chris Ady
on Jun 10, 2015 at 9:16:24 am
Hey guys, I'm trying to make a spot light follow a null object but it doesn't work. I copied the position of the object to the light, I parented the light to the object but when the animation of the object starts, the light goes the other way.
Any thoughts?
Thank you.
Jordan Quackenbush
Re: Spot light doesn't track a null object
on Jun 10, 2015 at 5:06:37 pm
Can you post your file? That will help to see the specific issue, as that shouldn't be happening.
Do you have any expressions happening which could cause it? Is the null set to 3D?
Jordan Q
If I'm posting a question, it means I've Googled it for far too long and couldn't find a solution/answer.
Cassius Marques
on Jun 10, 2015 at 7:30:28 pm
[Chris Ady] " I copied the position of the object to the light"
A spot light has a point of interest. If you copied your layer's position to the light's position, it would mean that when your layer moves, your light will move and rotate towards its point of interest thus seeming to go the other way.
[Chris Ady] " I parented the light to the object but..."
Did you do both? or did you tried each? Parenting alone should work.
Chris Ady
on Jun 10, 2015 at 8:11:27 pm
Yes, did them both.
Tried to copy and parent, then parent alone, didn't work.
