Optical Flares Plug-in not working on after effects cc
Liam O'Shaughnessy
on Jun 9, 2015 at 3:28:46 pm
I've recently installed Optical Flares from Videocopilot.com and was using it fine on my pc and tried to move it to my laptop to bring to school. When trying to use it on the laptop optical flares works fine until i view it. These light lines show up and none of the xy positioning works. I need this for an assignment at school any help would be awesome
Thank, Liam
Cassius Marques
Re: Optical Flares Plug-in not working on after effects cc
on Jun 9, 2015 at 6:34:12 pm
You should check your hardware's gpu compatibility in VCP's product page. If it is, see if any driver update is available.
Walter Soyka
on Jun 10, 2015 at 1:10:12 am
Optical Flares has a "GPU" property that can be unchecked to force CPU rendering. Does that help?
Walter Soyka
Liam O'Shaughnessy
on Jun 10, 2015 at 4:30:45 am
Thank you so much, this did help the problem.
