Control Error Expression
Tiago Cav
on Jun 3, 2015 at 1:54:56 pm
I'm using an expression with "sourceRectAtTime ()" in the Scale of a text. Works correctly, but when I turn out the text completely, the expression results in an error. Because try to find a value in "sourceRectAtTime ()" which is 0, but my expression is a calculation that divides a value by "sourceRectAtTime ()". And can not divide a value by 0, this is the error.
Is possible use a try/catch block which will test a block of code for errors while executing; if an error in the try block occurs, then the catch block is executed.
But I do not understand how it applies.
  • I want to know how to use it for use when no letters in the text layer, not cause mistake, just turn off the expression.
  • I want to know, also:
  • How to represent "None" in an expression?
  • I need use this Expression, adding a control of Errors.
    s = 70/sourceRectAtTime().height * 100;
    [s,s]
    Thanks.
    Kevin Camp
    Re: Control Error Expression
    on Jun 3, 2015 at 4:39:40 pm
    there's a few ways to handle it. try this:
    h = sourceRectAtTime().height;
    if (h=0) s=0 else s = 70/h*100;
    [s,s]
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
    Kevin Camp
    on Jun 3, 2015 at 10:55:31 pm
    sorry Tiago, I made a mistake in the syntax.
    try this:
    if (h==0) s=0 else s = 70/h*100;
    [s,s]
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
    Tiago Cav
    on Jun 4, 2015 at 2:08:37 am
    Awesome! Work perfectly.
    Thank you so much!
    Kevin Camp
    on Jun 4, 2015 at 5:33:19 pm
    you can usually represent none with empty quotes: "" or ''
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
    Tiago Cav
    on Jun 4, 2015 at 7:16:28 pm
    Thank you!
