Most Efficient QuickTime w/ Alpha
Michael George
on May 25, 2015 at 6:39:10 pm
I'm creating a running clock animation for a sports webcast that uses Telestream's Wirecast. Because the composition is very long (the length of the game), I'd like to know the best route to deliver a QuickTime with alpha that minimizes file size.
Walter Soyka
Re: Most Efficient QuickTime w/ Alpha
on May 25, 2015 at 6:46:24 pm
There's really no such thing as a light-weight production codec that supports alpha.
For a clock, I'd use QuickTime Animation codec, but since it only update every second, I'd make the comp and output movie run at 1fps; that'll instantly cut the file size by a factor of 30.
Walter Soyka
Matthew Woods
on May 26, 2015 at 2:55:49 pm
1 fps is a great idea. Another thing to consider is having separate rgb and alpha movies, and luma matting/track matting the color movie with the alpha. Then you can use whatever codec you want for your rgb. Depending on your animation, for something like a clock, you might even be able to use a still image for your alpha channel.
Need a quick break from motion graphics?
Try my game Constellation at:
http://www.paperdragongames.com
