Using throw with another expression
Andy Willers
on May 25, 2015 at 1:56:26 pm
Hi all - I want to use the throw expression to animate a null along the y axis, but have another expression moving the null on the x axis already - when I put in the throw expression it overides the movement that the other expression is giving the x axis - is there any way I can limit the throw to just changing the y value?
Here are the two expressions I want to use -
// Throw (move at a constant speed without keyframes)
veloc = 10; //horizontal velocity (pixels per second)
y = position[0] + (time - inPoint) *veloc;
x = position[1];
[x,y]
and
transform.position + 45*(0,thisComp.layer("midi").effect("ch_3_pitch")("Slider")-60)
Any help would be amazing!
Cheers!
Andy Willers
Re: Using throw with another expression
on May 25, 2015 at 2:02:27 pm
Silly me! I figured out it by using:
veloc = 250; //horizontal velocity (pixels per second)
x = position[1] + 45*(0,thisComp.layer("midi").effect("ch_3_pitch")("Slider")-60);
[x,y]
